The driver board manual does say that you have to move off the switch to re-enable the axis, if using the board's limit switch inputs.
Seems quite possible. I just am not sure how to wire things up to let both the driver board and the software know that an E-Stop has been hit. The driver board operates off of a higher voltage that the parallel port, so it doesn't seem straight forward.
That seems to be a given as the Mach3 manual also states
It will not generally be possible to continue machining a part after an EStop but you and the machine will at least be safe.
LinkBack URL
About LinkBacks
