Need Help! REFILL "A" AXIS OIL
Results 1 to 3 of 3
Thread: REFILL "A" AXIS OIL
    Jun 2017
    Default REFILL "A" AXIS OIL
    Hi hoping you can help. we have a Roctech RC 1240SA and have noticed the oil level in attached picture slowly dropping. our Maintanence man seems to think it may be gear from the "A" Axis. Is there an area that we can refill this as we don't want it to run dry ?
    We cant get to the top without pulling the top covers of and the only exposed surface is the underside which seems to have a slight leak
    We would appreciate any help ASAP as we would not want it run dry and cause any down time.
    Attached Thumbnails Attached Thumbnails REFILL "A" AXIS OIL-oil-4-jpg   REFILL "A" AXIS OIL-oil-3-jpg   REFILL "A" AXIS OIL-oil-6-jpg   REFILL "A" AXIS OIL-oil-5-jpg
    Jun 2009
    China
    Default Re: REFILL "A" AXIS OIL
    Hi Darren, sorry we lost the login ID for long time, did you get any solution from Roctech support?
    Jun 2017
    no nothing yet. hoping you can shed some light on it
REFILL "A" AXIS OIL
REFILL "A" AXIS OIL
