Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 02-08-2010, 08:05 AM
Curmudgeon is on a distinguished road
So far, so good.
Admittedly this is the easy part. Not too many mistakes, but there is one I decided to just live with that's pretty visible. Hopefully it's not critical to the design. I used 2x2 aluminum for the base because it was right there next to the 5/8 rod when I was picking it out and it seemed like a good idea. Decided not to paint, but do have 2 coats of poly shield (water based poly) on all the parts now. I have everything cut out, and everything I can assemble at this time is assembled and square. Waiting on bushings for the serious glue ups. I have most of Saturday and today in it, probably 16 hours or near it. Got my drive nuts from Dumpster (that was fast !) and the flange on them is too small for the 3/4 size hole they fit in. I should have use a smaller channel since I'm using 1/4-20 rods and don't need the 3/4 dia hole. However, it turns out a .5 dia fender washer fits perfectly under the flange and will provide me with the space to drill holes that will bite into the work piece. I may epoxy the drive nuts to the washer, or I may try to use the holes in the flange to attach it to the washer, not sure yet. I know I'll be mounting the Z drive nut on the bottom of the plate just in case it comes loose some day. I also took some of the 2x2 blocks that align the rods and put them on the lathe. I saw a picture of one using rounds blocks and I liked it.
Old 02-14-2010, 06:49 PM
Comming along nicely...
Old 02-18-2010, 06:27 PM
Basic A model is done
Had to fab a mount for the drive nuts.
Decided to fasten the rods for good once they were right !
Old 03-01-2010, 10:35 AM
maxmanbb is on a distinguished road
hello Curmudgeon
your project is coming along very nicely, I am looking at building a cnc too, I do not have fancy wood tools, but do have some, table saw, drill, router, did it take you very long to build?
thks max
Old 03-01-2010, 11:02 AM
It took about 6 days, but I worked in a bunch short spurts. It's done and cutting wood now, see the more recent post in the Rockcliff forum. Lots of work after the frame and hardware are done.
http://www.rockcliffmachine.com/foru...read.php?t=246
Originally Posted by maxmanbb View Post
hello Curmudgeon
thks max
Old 03-29-2010, 02:28 AM
mlmcquiggjr is on a distinguished road
What's up at the forum?
For more than a week I haven't been able to get in the Rockcliff forum.
Anybody know what's up?
Old 03-29-2010, 09:45 AM
It's been down, but no word on why, or when, or if, it will be back up ?
Old 03-29-2010, 07:37 PM
gadget47 is on a distinguished road
forum down....
Hi all,
I just sent a e-mail to Nick , i'll let you know (if he replies to me) what is going on. This happened awhile back when some updates were taking place. I'm sure we dont have to worry.
Gadget
Old 04-01-2010, 10:07 PM
forum
Hi all
I've been in touch with Nick (Rockcliff) about the forum-- Don't panic-there are some problems with the servers and their equipment. Remember we are dealing with wires and computers-anything can happen (and does).
The site was up for a day (or two) before it crashed again, we will just have to check here and (until everything works again)on rockcliff to see whats new.
Gadget
Old 04-02-2010, 08:58 AM
Thanks for keeping us up to date!
  #11   Ban this user!
Old 04-02-2010, 12:21 PM
forum..
no problem, by the way your machine looks awesome.
Gadget
  #12   Ban this user!
Old 10-14-2010, 06:23 AM
Markwind is on a distinguished road
Hello
great job, how did you find making your cnc from plywood? any dificulties, I am going to try working with plywood myself
Mark
CNCmachines6090 GOOD OR NO GOOD? CNCZONERAMICO Automation Technology Products 3 07-28-2008 05:25 AM
New EDM, Any Good? Spinner CNC Plasma and Waterjet Machines 2 10-04-2007 02:58 PM
Is this good enough the604tool General Metalwork Discussion 4 12-08-2006 04:10 PM
Tolerance, how good is good? Aerobuilt General Metal Working Machines 21 09-01-2006 12:02 PM
