I am building the Model A Imperial unit 18"x18"x7"
Below are the discrepancies I have found.
Okay, I want to make the following:
Gantry Plate 2 pcs.
For the 18"x18"x7"
In the A5.pdf file length = 19" (for the 12"x12"x5")(CORRECT?)
In the Size-Selection.pdf file length =18" (left side of pdf drawing for 12"x12"x5")(WRONG?)
Also, in the Size-Selection.pdf file length =20" (right side of pdf drawing for 18"x18"x7")(WRONG?) This drawing also states to add 2" to the original 12"x12"x5" plan height.
So, is the height for the 18"x18"x7" unit = 20" or 21"????
Looking at other dimensions I have deduced that it should be 21" in total.
Am I right or am I wrong?
B0SC0
