Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 10-22-2009, 08:24 AM
PotvinGuitars is on a distinguished road
Help with lead screws (ACME vs UNC)
I'm just finishing up a Model D build and I have some questions about lead screws.
The table is 4' x 3' (working area of ~ 3' x 2'), so I have 4' and 3' lead screws. I used 1/4-20 threaded rod, and while jogging, I noticed that even at 10-12 inches per minute the 4' rods whip like skipping ropes!
My first question is, will a 1/2" rod eliminate the skipping rope on a 4' span?
Assuming I solve the skipping rope issue, I'd like to crank out more than 10 ipm. I've heard legend of similar sized D models getting 20-25 ipm which would be great. Would switching to 1/2-10 ACME lead screws improve my ipm dramatically?
Lastly, if ACME screws are the answer, are the screws with more than one start more accurate? Greater resolution? or is single start all I need?
Thanks,
Mike
Old 10-22-2009, 09:11 AM
ger21's Avatar
My 60" 1/2-8 2 start whips a lot over 100ipm, but I can still run it reliably at 150ipm. My 40" Y axis whips a small amount when the nut is to one side, but not enough to cause any problems at 180ipm.
My Z axis is 1/2-10 single start, and I get 55ipm. These speeds are using a Xylotex at 24V.
You really should be using 1/2-8 or 1/2-10 acme 2 start. It's at least twice as efficient as all thread, so you'll lost a lot more power due to inefficiency.
Old 10-22-2009, 09:17 AM
Thanks Gerry. What's the advantage of 2 start over single? I can source single start locally so I'm wondering if I should go to the effort of Internet ordering 2 start from the US (I live in Canada )
Mike
Old 10-22-2009, 11:29 AM
ger21's Avatar
It's more efficient, and will usually double your speed.
Old 10-23-2009, 06:55 AM
Ah yes, I see. Two start halves the turns /inch. Thanks!
Old 03-25-2010, 12:28 PM
aslatte2 is on a distinguished road
While all this is true, what would be the difference between "ACME 1/2-10 2 start" and "ACME 1/2-5 1 start"
Old 03-25-2010, 05:17 PM
ger21's Avatar
I've never seen 1/2-5 single start, but my guess is the 2 start would be more efficient.
Ball screw or Acme lead screws bgolash Polls 18 05-10-2010 03:44 AM
Where is the best palce to buy acme lead screws reeftoker75 DIY-CNC Router Table Machines 4 03-29-2009 08:08 PM
Needing to source some ACME lead screws 1/4-20 Fixittt Linear and Rotary Motion 2 01-29-2007 04:59 PM
Max RPM of 1/2" ACME lead screws? Tom Brown Open Source CNC Machine Designs 3 09-11-2006 02:34 PM
Cheap ACME Lead Screws mjarus Linear and Rotary Motion 13 05-03-2006 10:22 PM
