| Rockcliff Machine Discuss Rockcliff Machine here! |
| Hi All, I have just about finished a Mini Model D. I scaled down to 24 x 36 inches due to space constraints and the fact that I was using parts I had purchased for a different design. I would like ask a few questions, please forgive the rambling run on sentences that my follow, it takes me too much effort to write 'correctly' The drive system is comprised of the following: 5/16 18 tpi lead screws pacific scientific motors rate at about ~118oz 24v 6a power supply, xylotex 3 axis and probotix side step (1 axis) using 1/4 steps All driven by EMC2. My max speed at the moment is 24 ipm, I am pretty happy with this, does this sound about right for a max speed? I have cut a few parts out of 3/4 inch MDF using rotozip bits, they come out a bit rough, I figure this is probably the bit. Any recommendations of how fast and deep I should run for a rotozip bit? Also, I am getting some noise from the screws while running, I would like to apply some sort of lubrication, but I am not sure what to use. I used the nylon wingnut approach, except I used 2 per slide instead of one, adjusted so they still spin easily but there is virtually no backlash (not sure how long this will last). I have graphite, but I have read a few messages that state this is not appropriate, and that beeswax would do the trick. Any suggestions? I am pretty excited about getting the machine running smoothly, and I am amazed it is working this well. Any help or guidance you guys could give me would be greatly appreciated. Thanks, Don Bailey (Sorry if you are seeing this again, I cross-posted this to the Rockcliff Site Fourm) |
| Tags |
| model d, question, rockcliff |
| Need Help!- A few questions to start a DIY mini CNC | Purple_rob | General Metal Working Machines | 7 | 06-09-2009 12:10 AM |
| Haas' new Mini Mill 2 model at Westec | HAILINHAAS | Haas Mills | 13 | 03-11-2008 05:46 PM |
| Model/dimensions of mini-lathe headstock | noahl | Vertical Mill, Lathe Project Log | 2 | 02-09-2008 07:20 PM |
| Solid Model CAD file(s) of HF 44991 / X2 Mini Mill? | blades | Benchtop Machines | 2 | 12-26-2007 07:05 PM |
| more mini-mill Z questions... | megavolt | Benchtop Machines | 8 | 12-02-2005 08:59 AM |
