Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 02-05-2009, 03:53 PM
wassupcrew is on a distinguished road
Cheap linear guides
Hi everyone. this is for those who are on a budget build. The cheapest way to build a type A rockliff machine is instead of using precision ground bar for the linear bearings, use EN24 bright steel bar. Its relatively accurate and hard, and works fine. Cost wise, I just bought 6 meters of 5/8 diameter for £25 compared with about £2 for 100mm of precision ground. Just thought i'd let people know if they're on a budget
Old 05-31-2009, 10:37 PM
steampunk is on a distinguished road
Thanks for that. Do you have any links to the EN24 and £2 precision bar?
Old 06-03-2009, 11:39 PM
draughted's Avatar
draughted is on a distinguished road
i agree. i got advice from my steel supplier and bright ground bar was perfectly acceptable for my application. and the price is a huge relief to a first time buyer.
any large steel supplier should be able to help you out, just ring ahead.
Linear Guides rgillard Linear and Rotary Motion 7 01-18-2008 12:16 PM
hiwin linear guides eloid DIY-CNC Router Table Machines 0 12-04-2007 09:04 PM
Linear guides help !!! zeoncomp CNC Plasma and Waterjet Machines 2 09-04-2007 02:04 PM
Linear guides canadamaxxer CNC Plasma and Waterjet Machines 0 11-30-2006 01:32 PM
Installing linear guides WayneC Linear and Rotary Motion 3 06-17-2006 03:37 PM
