| Rockcliff Machine Discuss Rockcliff Machine here! |
#25
| I use 2.5MM pitch screws on mine although if I was to replace I would go with 5MM as the 2.5MM with 2:1 resolution is no longer needed as no more machine dies for an injection moulders is needed (they bought a VMC) I use 1.8nm motors at the moment and have no need for any more "power" they are Chinese Nema23 FL56 type. After 8 hours of machining today they were (the motors) 36C and the gearbox output shaft 32C (Cooled by the coolant which was 33C) Todays CNC project was a flying gantry router upright. Both programs I like very much Images of my mill internals can be seen on my gallery site
__________________ Keith |
#26
Well currently the ACME screws are I think 25 or 30mm diameter with 3mm pitch I would think you could quite safely get away with a 20mm dia ball screw. 5mm pitch would be ok because if you use stepper motors you’ll probably need to gear down which will in turn increase the resolution of the step. E.g. my setup is 200 step 1.8° motor, 3mm pitch and a 3.33:1 gear ratio, Current 3mm pitch ACME screw resolution (3mm”pitch” ÷ 200”steps per rev”) ÷ 3.33”ratio” = 0.0045mm per motor step (more than enough) Ball screw 5mm pitch (5mm”pitch” ÷ 200”steps per rev”) ÷ 3.33”ratio” = 0.0075mm per motor step (still more than enough) Obviously those figures are for a perfect world if there was no backlash, belt lash or leadscrew end play. I use 425ozin(30.6kg-cm) bipolar steppers by Kelinginc.net with the gearing it has increased the torque to 1415.25ozin(101.898kg-cm) @ approx 110rpm. Mach 3 is what I use and does not miss a beat, just install a lean copy of XP and away you go. Just get a dedicated PC for controlling the mill and nothing else and you be fine, a touchscreen is nice too as Mach 3’s interface is designed for and Mastercam X for the programming.I use a Rockcliff 4 axis controller with parallel interface and Break out all in one and a dead synch to setup, although it is open loop as long and you don't try and drive the motors too hard you won't have and positioning issues. Cheers, Adam. |
#27
Doug, I plan to cnc the 320g. Have the lathe and ballscrews. Still to buy motors. Haven't had time due to work as well. Looks to slow down a bit next week. Look to be building some interesting machines. I'm nearby if you want to meet about the 320g. Mark
#29
| Hi Kipper, Xasertech (Adam), Holycross and mkc2 I have been busy the last few days but have just had a look at Kippers gallery. Superb work. Very impressed with what Kipper has done on a retro cnc'd machine. Thanks Kipper and Adam for the ball screw suggestions for the HM-35. It seems like 20dia x 5mm pitch ball screws with 2 or 3.3 : 1 timing belt reduction and a 2 to 3N.m stepper motor will be OK. I guess these are for the X and Y, what ratios and motor torques do you guys suggest for the Z and column? I have a spare license license for Bobvad V19 and the yet as unutilised Mach 3 license and several 20diax5Pitch screw offcuts so all looks good to start with a few clear weeks coming up! Would like to catch up Holycross re the Al320G project you are planning and which I need to do as well. mkc2 that is one of the tidier and finished router I have seen a - I would like to hear what software control you are using in software and what stepper drives and motors you have. Thankyou all for all your input and good to see Perth has a CNC scene! Regards dmenz (Doug)
__________________ He who rides the tiger finds it hard to dismount! |
#30
| Hi Doug Some info on what im using, my drives are RTA (Italy) GMD02 which run up to 6 Amp and steppers are 5.1nm Attached are the spec's and you can buy local. Software im using is mach3. Last edited by mkc2; 05-09-2009 at 04:53 AM. |
#31
Michael, Thanks, I guess you are using Dean Walker's Automated Motion Systems, superb friendly service. I use Dean's very high quality SD motors and RTA NDC drives when I need a broad speed range. Good choice. Sounds like Mach 3 is highly regarded, I intend to try my license out this coming week. Regards Doug.
| need planetary gear head | eloid | Servo Motors and Drives | 4 | 03-19-2008 12:11 AM |
| Gear head for Size 34 motors | Larken | Automation Technology Products | 9 | 06-18-2007 08:46 AM |
| noise level of 3600 RPM motor with gear head | Runner4404spd | Industrial Hobbies (Support forum) | 10 | 12-10-2006 01:42 PM |
| M head conversion? | teufel | Bridgeport and Hardinge Mills | 3 | 01-10-2006 07:44 PM |
