Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 01-01-2008, 08:50 PM
Oldbill is on a distinguished road
Exclamation Cutting Cogs for Wooden Clocks
I am fairly new to the cnc world and I just finished the Rockcliff router and things have turned out well.
My question is that when I draw a clock cog on autocad and import the file to Mach3 software the G code is generated and all seems well until I acutally run the program. The toolpath seems to follow the inside of the cog and not the outside. Am I missing something in the G code to compensate for this?
Oldbill
Old 01-16-2008, 08:52 AM
cncboss6's Avatar
cncboss6 is on a distinguished road
Smile
Yes, read page 9-1, 9-2, and 9-3 in the mach 3 manual. Your on the wrong side of your cutter path. Make sure your tool table is set up properly with the correct tool diameter, and mahe sure in your tool change you are calling up the correct information. use a g41 to turn comp on and a g40 to cancel it in your program. Hope this helps, Pat
Wooden puzzle and general cutting advice mriehm Laser Engraving & Cutting Machines 2 10-21-2007 05:30 PM
Wooden Works Clocks bobbytbird Hobby Discussion 2 04-17-2007 04:29 AM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) snooper Linear and Rotary Motion 13 02-28-2007 06:28 PM
Cutting out wooden letters? WarrenW WoodWorking 2 10-15-2005 09:46 AM
FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc ) chuckknigh DIY-CNC Router Table Machines 44 12-31-2004 07:54 AM
