i just used drywall screws. you will find the need to remove your motors so dont use glue.
i have had to remove the motors because the couplers slipped even the dumbster one slipped. it wasnt tight enough.
Hi All and Merry Holidays!
I am to the point of my construction where I need to figure out how to mount the motors to the mounts. Do I use wood screws or use long 6-32 screws and glue them in place? Can anyone give me examples of what they did? The build sheets don't really say how to do it.
Thanks,
Rene
Hi Rene,
This is the way I mount my motors to the frame.
Using the nuts (see the photo) from the DIY shop, whit M5 hex screws.
You also can see the tool I used for drilling out the pocket in the plate.
The motor plate can be bolted or screwed to the frame.
Success Hans
Thanks, that was great help. That looks like a nice way to do it.
rene
