Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 12-18-2007, 01:21 PM
stevef12005 is on a distinguished road
M8 Thredded rod lead screw Help
Hi everyone could some one please tell me what setting on mach 3 should i use for M8 thredded rod as my lead screws on the X Y Z
I hope this make sense
as in steps or velocity acceleration
many thanks steve
Old 12-26-2007, 11:07 AM
craigtx is on a distinguished road
goto the mach site and look under the tutorial vidio and trubleshooting at the bottom
this shows how mach will set the steps for you. acc. is up to each machine,if you set this to high the steppers will stall or sound bad.
lead screw frankg521 Mechanical Calculations/Engineering Design 0 04-29-2007 03:38 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 12:23 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 09:42 PM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 09:49 AM
Ball Screw and Lead Screw ljoe1969 DIY-CNC Router Table Machines 9 11-21-2003 09:06 AM
