Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 11-02-2007, 09:03 AM
anakinjay is on a distinguished road
how deep will it cut?
Question:
I'm going to be building one of these regardless, but I was wondering...
How deep will it cut? like if I have a 6 inch block of wood, can I go all the way through it 6 inches, and have some parts be 6 inches tall?
What I have in mind is, I want to make molds for face plates for various costumes, that I can then use a vaccuforming machine on... It would probably have to be 10" x 6" and would have to go from 0" on the edges all the way to 6" or so at the top of the arc, and be able to cut in the details.
Thoughts?
Old 11-02-2007, 09:11 AM
ger21's Avatar
If it can't, you can always use a CAM program to slice up your part, cut it in seperate layers, and glue them together to achieve the final size. This will let you cut part much taller than your machine.
Old 11-02-2007, 09:22 AM
thats a great idea! I've never done that before though... is it difficult? (all of my modeling so far has been 3dstudio max based)
In at the Deep End!!! PlymUK General Metal Working Machines 0 08-19-2007 10:51 AM
deep grooving eject_21 G-Code Programing 3 06-15-2007 01:59 AM
Deep welding JBV Welding, Brazing, Soldering, Sealing 3 09-14-2005 11:00 AM
.250 Dia x 22.00 deep ?? Rekd Machine Problems, Solutions , Wireless DNC, serial port 10 02-25-2005 09:24 AM
Drilling deep holes. HSM Joe Machine Problems, Solutions , Wireless DNC, serial port 7 05-13-2003 01:14 PM
