Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 10-11-2007, 05:17 PM
stevef12005 is on a distinguished road
Question ok total newbie question i have looked hard & everywhere for carbon steel
OK i
ve got the Rockcliff plans ive stared the build i glued drilled & screwed, got the nema 23 equivallent motors but i'm stuck trying to find the 16mm Diameter W16(h6) Straightend and polished - Carbon Steel or equivallent as in my last post ive not got a lot of money (out of work with back injury) so money is tight i found out where to get the bearings (oillite) www.brammer.co.uk if anyone wants any, i have found this other place www.marchantdice.com but the steel from them is a lot more than what i can afford, there price is £85.86 US$175.25 AD$195. for the 6pc's
so i have look through the post & people are using tube so what can you use
i look forward to your reply because i have a lot to learn & plenty of time to do it?
thanks steve
Old 10-12-2007, 06:01 PM
BobF is on a distinguished road
appears you're in the UK. This may not be applicable, but in the US we buy what is called drill rod from industrial suppliers. I assume you ref 16mm in your post. That would be about 5/8 in inch size. Should be available. enco lists it for $11.21 for 36" length for .6300 inch (which they also call 16mm).
Old 12-08-2007, 11:05 AM
bigbigjimb is on a distinguished road
As in the readme file from Rockcliff try
http://www.metalsupermarkets.com/MSC...gion=UK&Map=UK
Get a price from them by phone, I have not tried them yet as I have not started the build but my next option after that would be an engineering supplier they are in most city's in the UK
Jim
Old 12-08-2007, 11:15 AM
thanks for that Jim i will have a look, i have built another type of cnc at the moment that i saw here http://buildyourcnc.com/latest.aspx but will get round 2 finishing my Rockcliff
thanks again steve happy christmas but a better hogmany
Old 12-08-2007, 11:47 AM
I have not decided what one to go for I want a fairly big one and i like the buildyourcnc one need to finish the CNC mill first though having problems with the servos turinig the correct way.
unmfortunatly I wont be home for either as I am working away planning and dreaming about what I have to do CNC wise.
Will miss my Hogmanay though.
Jim
Hard machining vs. carbon JIMMY Hard and High Speed Machining 11 11-16-2007 08:00 PM
Total Newbie needs YOUR help! JorG3 Fanuc 4 08-01-2007 12:21 AM
looking for a supplier of Carbon Fibre Hard sheet acidcustom Composites, Exotic Metals etc 3 07-22-2007 03:50 AM
Total CAD newbie after some advice wildstallionuk General CAM Discussion 3 10-20-2005 07:07 PM
Total Newbie question here redbaron General CAM Discussion 4 06-24-2003 03:02 PM
