Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Rockcliff Machine
Rockcliff Machine Discuss Rockcliff Machine here!
Old 10-11-2007, 01:55 PM
rlrhett is on a distinguished road
How wide a Y-axis?
Using the basic construction for the Y-axis (double precision rod with bronze bearing sleeves), how wide can you go before deflection becomes a problem?
I am looking for a setup that will give me about 18" of cutting accross the Y-axis. I gather I would need to construct a Y-axis using aprox 28" rods. Assuming I am building the z-axis to the usual spec and mounting a Hitachi router, how much defelction might I expect at the center? Would this be too large of a span? I'm looking for about +-0.01" precision.
Thanks,
Old 10-11-2007, 04:06 PM
anoel's Avatar
anoel is on a distinguished road
What's the diameter of the rod?
With a heavy Z and a full sized router, you'll want to keep that axis pretty short or use some big rod (Think 1" dia or more for that 28" span). I'm running a 20mm usupported rod on my 24" Y axis and using a rotozip as a spindle. I can deflect the y axis very easy. If I had a full sized router on there it would be rediculously amplified.
What'll happen is that router doing any kind of heavy cut will shake the Sh!t out of the Z which will cause torsional flex of the Y axis...
Nathan
Old 10-11-2007, 06:07 PM
I was thinking of using 3/4" rod (close enough to 20mm), so you answered my question. What a pain! Supported rails add SOOOOOO much to the complexity and cost, but a CNC that couldn't cut a piece 18" wide is not of much use to me.
I'll post the question over at the Yahoo group as well for contrasting opinions, but I guess I knew the answer even before I asked.
searching far and wide Gandalf Deckel, Maho, Aciera, Abene Mills 5 08-31-2007 10:35 AM
wide deep cut question fatboy55 Industrial Hobbies (Support forum) 16 12-22-2006 12:51 AM
wide, deep cut question fatboy55 Mini Lathe 2 12-14-2006 09:48 PM
How do you cut wide grooves with a small bit? randyf1965 DIY-CNC Router Table Machines 0 04-26-2006 09:09 PM
