Originally Posted by simplicity hello, this is my first try.
i have
1 Rockcliff plans
3 StepMasterNC SOP-1 1 axis bi-polar stepper motor drives
1 StepMasterNC DB25 breakout board
2 powermax II 144 in.lbs M21nrxa-Lnn-ns-00
1 powermax II 116 in.lbs P21nrxa-Lnn-ns-00
1 28V @ 11A Regulated Switching Power Supply
1 Mastercam x2
1 Mach3
does this look good so far.
I will be posting pictures as i go. i welcome advise. |
Hi It sounds like your well on your way, I like the quality of pacific scientific steppers that you have (powermax) if your planning a mid sized machine 100oz.in range will almost be the mininum you would want to use, just remember that stepper motors have less torque as they speed up, you will get results with your motors, and becuase they are a nema23 frame, swapping them later for a higher torque model will be easy.
