| Rockcliff Machine Discuss Rockcliff Machine here! |
| I have a 4 axis driver board and my Z axis socket for the A3977 driver is bad. I am not using the A axis and I am needing to know how I can get the A axis to work as the Z axis. I have a Mechtronics 4 axis board. All of the axises are socketed and driven by individual A3977 drivers. There is access at the rear of the board to the other pins not used but I can't access pins for the step and direction for the 4 axises. I primarily use the Cut2D software for my programs and I don't know if you can change "things" in the software which would be the simple way to make the A axis into the Z axis. HELP!! |
| Grinding and unexpected axis movement if rapiding 2 axis | DarkSabre | Taig Mills & Lathes | 4 | 03-25-2010 11:37 PM |
| the Difference of 2-Axis and 3-Axis of Vertical Mill Machine | begacon | Knee Vertical Mills | 6 | 07-30-2009 06:31 AM |
| Compare Catia and MCX2 for multi axis lathe/4 axis mill | bob1112 | General CAM Discussion | 0 | 10-10-2008 07:15 PM |
| How can I coupling a stepper motor axis directly to other axis? | meknik2001 | Stepper Motors and Drives | 4 | 05-08-2008 01:54 PM |
| New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter | the__extreme | CNC Wood Router Project Log | 3 | 02-26-2007 02:58 PM |
