Need Help! Rockcliff 4 axis controller with only 2 axis in use - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 26 of 26
Thread: Rockcliff 4 axis controller with only 2 axis in use
  1. #25
    Registered lmlamb's Avatar
    Aug 2009
    Default TB Detector
    Hi Jeff,
    I was basically of the same opinion, but, you know how it is, better to measure twice and cut once, eh? Sure appreciate the opine.
    Larry
    W4LML 20mtrs
  2. #26
    Aug 2009
    Default Re: Rockcliff 4 axis controller with only 2 axis in use
    Hi Jeff,
    Long time no talk to. I have an issue. I blew out the magic smoke on my rock cliff 4 axis board, and I find out I can't get a new one. The only thing available from Rockliff is a 5 axis controller interface board. Looks like the pin outs are same, b ut my question is this. Will the flood/mist relay require an optical relay the same way as the rock cliff 4 axis board? Also, is there anything special that needs to be done to setup the Estop, or is it the same as the 4 axis board also?
    Larry
    W4LML 20mtrs
