I would start by drawing a helix along and around the "hourglass" shape you are trying to wrap with the curve. Once that is done, select the curve, then select Curve_From Object_Pullback. Select the hourglass shape as the "surface that pulls". This will get you close. When trying this, I noticed that the curve is not projected exactly right, it pulls the curve normal to the surface.
Hope this helps a little.
Cheers!
LinkBack URL
About LinkBacks
