Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 04-02-2005, 03:27 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
Is it possible to get a gcode into Rhino
I have a gcode made from a photograph. I want to engrave the photo code onto a curved surface that I made in Rhino. Is there any way to import the gcode into Rhino so I can map it onto the curved surface?
Or is there another way to accomplish this?
Basicly I want to convert a gcode to a pointcloud or 3D model.
Thanks.
Regards Terry.....
Old 04-02-2005, 03:39 PM
DAB_Design is on a distinguished road
I would think that if you could take out everything except X, Y and Z values seperated by a comma, it could work. I don't think there's a way to get arcs or any G-code specific commands.
But I think it would have a value for all three axis.
0.00(X), 0.00(Y), 0.00(Z)
With a little effort, it could work. And maybe with a lot of effort, you could get everything (arcs) to import.
Old 04-02-2005, 03:42 PM
MrBean's Avatar
Gold Member
Yep. There's no arcs in the code. Just std X,Y,Z moves. Maybe I'll try importing it into a spreadsheet. I don't fancy deleting all the un-needed charaters in notepad.
Cheers..
Old 04-02-2005, 03:50 PM
MrBean, WordPad works very well for that. 'Find and Replace'.
If you want to post/send it, I'll give it a shot.
Old 04-02-2005, 04:09 PM
MrBean's Avatar
Gold Member
The photo code is 250,000 lines. It's mostly X,Z moves, as it's done raster fashion. Rhino will need X,Y,Z co-ords for each point in the cloud? That's a lot of Y values need adding.
Gcode is attached if anyone fancies a bash at it.
Cheers Terry...
Old 04-02-2005, 07:33 PM
ger21's Avatar
Here's a .dxf composed of lines. http://home.comcast.net/~ger21/CNC/d.../converted.zip
Old 04-02-2005, 07:51 PM
MrBean's Avatar
Gold Member
Whoa. Thats very cool. Any chance of letting the group know how it was done.
I'll have a play around with it later. See if I can wrap it onto a surface.
Cheers Ger21 Helpfull as always.
Regards Terry.....
Old 04-02-2005, 08:04 PM
ger21's Avatar
There is a program in the AutoCAD forum called GcodeIn. It converts Gcode to lines and arcs in AutoCAD. Thank Bill for writing it. It took a few minutes for it to draw the lines. Then a few more minutes to save the .dxf. (60+ MB) And another minute or 2 to .zip it. I need a faster computer, I guess.
Old 04-03-2005, 12:41 AM
oldjohn's Avatar
oldjohn is on a distinguished road
G'day
Check if you have a function to project a geomerty file or an .nc or .nci file onto a surface, as Mastercam has.
Good luck
Old 04-03-2005, 01:47 AM
oldjohn is correct. Build the surface you want to engrave the image on. Then use the 'project' command. It would probably be best to group all the curves together, that way you don't have too hard of a time selecting them all.
Gerry, is there any place that us common folk can get that program?
  #11   Ban this user!
Old 04-03-2005, 01:54 AM
Actually, after thinking about it for a minute, project will not work. All that will do is give you straight, horizontal lines along your surface. You'll have to get creative on this one.
Old 04-03-2005, 07:41 AM
ger21's Avatar
You need AutoCAD to use it. http://www.cnczone.com/forums/showthread.php?t=2092
[IMG] code is Off
Rhino to Gcode? Fred in NC Rhino 3D 20 05-12-2008 09:13 PM
Rhino 3.0 vs AutoCAD JRoque Rhino 3D 8 02-04-2005 05:41 AM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 06:51 PM
Courtship Kills Rhino WallCrawler CNCzone Club House 1 05-21-2004 09:33 PM
Gcode verify autocad plugin balsaman General CAM Discussion 1 10-31-2003 11:22 AM
