Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 03-10-2005, 08:24 PM
Calico is on a distinguished road
Thumbs down Rhino free Turorial for CNC ??
where can I find Rhino Tutorial for modelling to CNC ?
any tutor for free ? web site ? video to download ?
regards
rud
Old 03-10-2005, 09:12 PM
DAB_Design is on a distinguished road
Rhino is only for drawing/designing your part(s). It will not output the G-code needed to run your machine. You will need CAM software for that. Rhino, I guess would be considered CAD (computer aided drawing or drafting).
There are several tutorals for using Rhino for CAD work. There are even a couple encluded when it installs. You could probably find seveal more just by doing a google search.
Old 03-11-2005, 08:04 AM
Rhino tutor to g-code to CNC.
what I meant is work flow from rhino, cadcam, gcode.
maybe sample from rhino and convert file to gcode.
is there any tricks when doing gcode ?
what about 4 axis or 5 axis ? how you set the 4 or 5 axis to cut ?
sample would be enough for me to learn.
i hope someone put that on url
rud
Old 03-11-2005, 01:47 PM
Dogsione is on a distinguished road
I don't know if this helps...
RhinoCam has VisualMill basic built into Rhino. There is a video tutorial here:
http://www.rhino3d.tv/RhinoCAM/RhinoCAM.htm
It only does 3-axis as far as I know.
Otherwise, I would search for the Cam software that you wish to use first (4 or 5 axis) and see what tutorials they offer. Rhino will output a file just like any other CAD program.
My workflow would probably look like this:
1. Model in Rhino3d. Save with the appropriate extension (.dxf, .stl, etc.)
2. Import into your CAM software (I use SheetCam and MeshCam, for example). This creates the necessary toolpaths and G-code depending on your machine. Save as a text file (.nc, .tap, etc.).
3. Import into your controlling software (Mach2).
4. Cut your material.
There are of course many variations to this depending on the software packages you choose.
ID:	6124   Click image for larger version
ID:	6125   Click image for larger version
Old 03-11-2005, 10:28 PM
workflow
This is all i need, post more guys...
Old 03-17-2005, 04:06 PM
NickLatech is on a distinguished road
Can Mach2 import DXF files that Rhino exports? I trying to go from Rhino to mach2 for making a pcb board.
Nick
Old 03-17-2005, 04:46 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
Yes it can. That's how I made mine.
Regards Terry.....
Old 03-20-2005, 03:05 AM
strat's Avatar
strat is on a distinguished road
one thing i noticed on this is you have to explode the image for it to go in ok gotten many unsuccessful imports and was going nuts i don't remember where i saw this but it did seem to help
Old 03-20-2005, 12:22 PM
You could try Ace converter as well...
http://www.dakeng.com/ace.html
Plus, it's free!!!
[IMG] code is Off
Is it possible to get a gcode into Rhino MrBean Rhino 3D 11 04-03-2005 07:41 AM
Rhino 3.0 vs AutoCAD JRoque Rhino 3D 8 02-04-2005 05:41 AM
Rhino Fillets in MasterCam BarnBurner Mastercam 17 10-24-2004 09:54 PM
What a GREAT program! tauscnc Rhino 3D 54 06-07-2004 01:52 PM
Courtship Kills Rhino WallCrawler CNCzone Club House 1 05-21-2004 09:33 PM
