Results 1 to 10 of 10
Thread: Need to round over the top on a part Help.
    Dec 2006
    So I'm making this yoke pictured below and instead of spending lots of time trying to figure out how model a curved top I was wondering if there was an easy way to put a curved top on this part, you know just rounded over so there is a little relief to it so it's not so square. It would have to be made with a ball nose bit as I need to do it on both sides. So I'd mill the rounded part on one side, flip it, mill the rounded part again and then do the cut out. Sound good?
    Attached Thumbnails Attached Thumbnails Need to round over the top on a part Help.-yoke.jpg
    Dec 2006
    I'm building a 4th axis so I don't know if it would be easier to use a 4th axis, bolt this part on after it's cut out and do some kind of roudning operation. I've never done 4th axis work so I don't know how hard this would be. I do have RhinoCAM 1.0 Pro which has 4th Axis capability.
    Jun 2005
    I can't speak to the machining of it, but as for the model, you can use a Solid/Fillet to round over the top, and by selecting the top edges. I do think that square corner inside the yoke will give you trouble, filleting, machining, and finished part.
    Dec 2006
    Thanks. I'll try that.
    Dec 2006
    I was fooling around with the fillet and chamfer commands the problem is there are so many. I couldn't figure it out. First I did an extrusion to make it a solid but that didn't help. Every time I applied the fillet it came out with all these weird shapes that made it look like the Super Dome. Any help would be appreciated. Thanks.
    Jan 2009
    No there's no such thing as as simple way to just "put a curved top" on a part, not a shape like that anywya. It looks simple enough to make as 2 or three curved shapes, one for the bottom part, one for each 'fork,' one for the little 'protrusion' on the end, and blend/fillet them together.
    Rhino Sales, Training, Consulting
    www.hydraulicdesign.net
    Dec 2006
    I don't really know what I was thinking. I just did a 2 rail sweep with a multiple arcs. Thanks for the help though.
    Dec 2006
    OK so I've got the tops rounded but don't know which method I should use to machine this so it efficient, parallel machining? Oh I have RhinoCAM 1.0 BTW.
    Also in RhinoCAM how would I program a corner rounding endmill, because that might be an alternative.
    Feb 2007
    I just did a quick (5 minute) sketch with Rhino, and use the fillet surface command. Is this what you want?
    Attached Thumbnails Attached Thumbnails Need to round over the top on a part Help.-yoke-radius.jpg
    Dec 2006
    I apprecaite the help but I already got the answer, thanks though.
    1. 2D Contour on a round OD not very round :(
      By kojack in forum Mastercam
      Last Post: 08-10-2008, 08:07 PM
    2. Newbie- Part holding and milling 3D part on 2.5D Mill?
      By john_t_h in forum General Metalwork Discussion
      Last Post: 03-15-2008, 07:35 AM
    3. Missing steps on just a certain part of the part
      By ZipSnipe in forum Stepper Motors and Drives
      Last Post: 01-02-2008, 02:40 PM
    4. Fixture for holding 31/32 Round Part
      By Smackre in forum Work Fixtures and Hold-Down Solutions
      Last Post: 06-03-2007, 09:24 AM
    5. RFQ- small little round part needed
      By fastolds in forum Employment Opportunity
      Last Post: 12-07-2005, 08:04 AM
