Results 1 to 3 of 3
Thread: Rhino problem splitting OBJ file Part1
    Oct 2006
    Ok I have a file imported into Rhino from ZBrush (obj)
    I need to create a parting plane for molding. If I create a solid or surface sphere I can split the object into two halves using a plane or a plane that is created from 4 curves that resembles a sheet blowing in the wind without any problems.
    Once I move the plane back into position to cut through my model I perform the exact same operation Rhino takes about 20-25 minutes to do it's "thinking" and then it's done. I then try to move one half or the other and the model is still one solid piece.
    I've tried split as the object were a mesh and a solid. Rhino won't select it if I try to do a solid so I have to use the mesh boolean split.
    Any ideas? It's a 1.2 million poly model which I think is the issue.
    Sep 2004
    Switzerland
    Rhino's mesh tools are not extremely reliable, especially anything that needs a mesh-mesh intersection. Hoping for success in trying to split a 1.2 million poly mesh is very optimistic...
    As you surmised, the only tools you can use on your object are the mesh ones, normal split/trim/boolean ops for surfaces do not work on meshes.
    I do not have an answer for you on this, aside from finding another tool to work with meshes... --ch
    Jun 2005
    Rhino's strength is Nurbs. I would split the mesh before it comes into Rhino.
  1. Need Help!- Splitting entities
    By Claude Boudreau in forum Vectric
    Last Post: 04-29-2009, 08:37 PM
  2. Importing Rhino File
    By buggie in forum Mastercam
    Last Post: 04-13-2009, 01:51 PM
  3. trouble saving rhino file to useable DXF
    By bradyfb in forum Rhino 3D
    Last Post: 03-30-2009, 09:26 PM
  4. Rhino Toolbar default file
    By flat6turboGT1 in forum Rhino 3D
    Last Post: 03-14-2009, 09:50 AM
  5. Generate G code from rhino file
    By mredican in forum Rhino 3D
    Last Post: 02-23-2008, 06:51 PM
