Results 1 to 3 of 3
Thread: Offsetting surfaces they wadd up ..
    May 2007
    I have a bent tube that I need to offset .250
    it keeps wading up the surface any fixes for this ?
    Sep 2004
    Switzerland
    I suspect that you're trying to offset it more than the inner bend radius will allow. If you were to do this with a real tube it would fold... So you're probably going to need to construct it differently so the offset will work, like changing the radius of the bend so it will fit.
    Attach a file and someone can have a look at it for a more precise answer. --ch
    Nov 2004
    I would suggest rebuilding the tube; I think that would be the easiest way in this case. Construct a curve that travels through the center of your old tube. The select Solid_Tube, and press enter. It will ask you for the inside dia, as well as the outside.
    As chill suggested, you may have to change the bend radius to make this work.
    Hope this info is useful.
  1. Need Help!- Can't move on Z/X when offsetting.
    By SpeedsCustom in forum LinuxCNC (formerly EMC2)
    Last Post: 05-24-2008, 04:52 PM
  2. Offsetting the Cutter
    By saxman727 in forum G-Code Programing
    Last Post: 05-18-2007, 04:53 PM
  3. offsetting tools
    By earl in forum General Metalwork Discussion
    Last Post: 05-03-2007, 12:28 PM
  4. offsetting tools
    Last Post: 02-22-2007, 04:14 PM
  5. Offsetting Polylines
    By tahlinc in forum Tahlcam
    Last Post: 10-08-2003, 07:35 AM
