Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 10-29-2004, 12:21 PM
smythe is on a distinguished road
Radius between tangents?
Hello-
I was wondering if someone would be able to help me out with a function. I have been taking some AutoCad courses and then trying to apply what I have learned in Rhino.
I would like to add a radius line in between two tangents, with Autocad its something to the effect of circle>tan tan radius.
I was able to get it done in Rhino but it seemed like hack..in Rhino I did something to effect of ..circle>tan>select first point> select second point or radius<5.00> ** at this point I hit enter and it placed a circle which I moved into positon in the window. I was curious if I could just select the two tangents and have it(Rhino) place the circle with the appropriate radius needed between them? I tried a couple of different ways, but none of them seemed to work properly. I could of very well left out a step.. it was late.
Any suggestions would be appreciated.
j
Old 10-29-2004, 01:11 PM
ger21's Avatar
Rhino has the same thing. Circle, tangent, tangent, radius.
Old 10-29-2004, 01:23 PM
I will give another shot tonight..I thought it would/should be the same everything else has been similar. One thing I forgot until just now is Circle>ttr .. will the ttr option work in Rhino as well or would I have to specifically circle>tangent (select)>tangent (select)>{enter radius} ..hope that made sense.?
thanks
j
Old 10-29-2004, 01:25 PM
ger21's Avatar
Go to the circle command in the menu, it's there.
Old 10-29-2004, 02:38 PM
Thanks, I forgot I had Rhino on this machine that I am on .. sure enough. Its still not doing what I want(or thought) it will do ( I am probablly using the wrong function). Example: I have a rectangle drawn starting at 0,0 that exends to 200,0 (mm) its about 30mm high. I need to draw a line from 0,0 to the 200,0 that has arc with a radius of about 1000mm ... am I using the wrong function? Any suggestions would be appreciated...
j
Old 10-29-2004, 03:00 PM
ger21's Avatar
Tangent to what? The top of the rectangle?
Old 10-29-2004, 03:14 PM
Actually Gerry... I think I may have got it by using the arc>start,end,radius. I guess what I wanted was just to draw a line from point a to point b that had a specific radius to it. Dont really know why I thought the tan tan rad is what I wanted. You rock though, thanks for the help, probablly wouldnt of found it with out your help.
Thanks again.
j
[IMG] code is Off
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 01:24 PM
Macro/Parametric Programming screensnot Fadal 4 03-28-2005 08:45 PM
need help with auto radius and chamfering dry run G-Code Programing 1 01-30-2005 02:52 AM
Programming lathe with radius numbers mudwhump BobCad-Cam 1 06-07-2004 07:14 AM
