Offset should work on a good curve. Try to fitcrv tolerance 0 degree 3 the dup border curve. That should create a new curve to very tight tolerance that you can then offset. Fitcrv, rebuild etc will make small changes to the curve so check to make sure it still matches your purpose.
LinkBack URL
About LinkBacks
Make test parts and adjust.
