Results 1 to 8 of 8
Thread: Rhino Twist Question
    Apr 2007
    Texas
    I have read the help files in Rhino and done a search here and did not find a good answer.
    I have been trying to figure the Twist function. I have only been able twist a 2D curve, and then only can get a 180 degree twist.
    I want to take a 3D rectangle and twist it a full 360 degrees, or atleast play with some different looks anyway.
    Could anyone point me in a direction to look for some good information on using this feature?
    Thanks,
    Registered duluthboat's Avatar
    Sep 2003
    Extrude a square along a helicol curve the pitch and length you want.
    Sep 2003
    OK! I just tried that and it's not so great an idea. ;-(
    Sep 2003
    Cool
    I made a square column marked a center point at top and bottom. I selected twist and followed the command line prompts. This is the result. First time I ever used that tool.
    Gary
    Jun 2003
    Gary that just goes to show you're a lot smarter that I am. I tried the same process, including the command line and got something that I wouldn't show! Actually it was real nice and I may carve one out of wood sometime just for one of those artsy projects!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    Sep 2003
    Once you establish the axis, pull a line out to one side and spin it around like you would for a rotate. As with all things CAD, I can do it but trouble explaining it.
    Gary
    Apr 2007
    Texas
    I can't even select a 3D object with this command active. Am I not holding my jaw right or something?
    Sep 2003
    Select the object before you go to transform. It goes something like this. I have this object, I want to transform it, I want to twist it, this is the axis of the twist, this the reference angle from where the twist starts, this how far and the direction I want to twist it. That’s the way I step it thru. Oh, and I stand on one leg looking north. ;-)
    1. Rhino question
      By Alnico in forum Musical Instrument Design and Construction
      Last Post: 07-17-2007, 09:35 AM
    2. Rhino script question
      By ohno in forum Rhino 3D
      Last Post: 06-20-2007, 05:59 PM
    3. split question in Rhino
      By turmite in forum Rhino 3D
      Last Post: 06-20-2006, 08:33 AM
    4. Rhino script question
      By sdantonio in forum Rhino 3D
      Last Post: 04-18-2006, 09:57 PM
    5. Rhino or Onecnc ? That is the question.
      By 1bordeaux in forum General CAM Discussion
      Last Post: 05-09-2005, 07:51 PM
