Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 08-25-2007, 02:43 AM
iipeacefrog is on a distinguished road
From a picture to the CNC
So I just moved into a loft in la, and i have to build the walls on my new room. the room gets extremely hot so i decided to take make some 'ventilating art.' I plan to take an interesting picture...pixelate it in photoshop and mess around with it until i get basically a grid of 1/2" circles spaced close together which still communicate the photo. I would then like to trace those circles in rhino or some program and then cut them out of plywood with a cnc. Due to the large # of circle holes there would be (prolly somewhere in the thousands), it would be extremely impractical for me to trace every one. Is there a way in rhino i can import the circle grid and do some kind of array to convert to a format friendly to a cnc?
Old 08-25-2007, 09:53 AM
spoiledbrat is on a distinguished road
Have you tried to export to corel draw, and then export as a dwg? I am not sure that will work, but that would be my first attempt. Dwg may convert the circles into line drawings.
Let me know if that does not work.
Old 08-25-2007, 10:24 AM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Lightbulb
Hey that's a great question...
You may be able to make the balls and select all then apply uvn to surface.
I would check here. I remember a question concerning a golf ball, this would be simular. http://www.renderosity.com/mod/forum...forum_id=12371
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-25-2007, 11:44 PM
HayTay's Avatar
HayTay is on a distinguished road
iipeacefrog,
You may want to take a look at this thread I started a while back that didn't get too far. You can access it here: Stippling (a.k.a. Pointillism) Program - Adoption needed.
Be sure to check out the two links in my first post. Maybe it'll be enough to get you started on your project?
You wouldn't happen to be a programmer that could take the existing "Stippling" program and massage the code a bit to make it more user and machining friendly, would you???
I hope this inspires you, or someone,
Name:	Weighted Voronoi Stippler - Screenshot.jpg‎
HayTay
Don't be the one that stands in the way of your success!
Old 10-10-2007, 01:12 PM
brianhoopajoo is on a distinguished road
"Meshcam art" easily machine 2d pictures into 3d reliefs.
www.meshcam.com 60 day trial.
[IMG] code is Off
Picture this.... UKRobotics General Metalwork Discussion 11 12-14-2007 06:16 AM
picture to engraving? hoagiem General CAM Discussion 42 11-26-2006 09:14 AM
Help with picture Wjman General CAM Discussion 3 03-13-2004 01:52 AM
How Do I Get A Picture Under My Name? CNCadmin CNCzone.com FAQ 0 04-12-2003 09:50 PM
