Kevin,
i had a look at it in Rhino 3 and noticed that there may be an issue with the edges not being joined at one or more points. The questionable area is circled. This may be a display issue as I couldn't snap to the extruded surface to do a distance check. Have a look at your file and see if you come up with the same thing.
Cheers
Splint
LinkBack URL
About LinkBacks
