Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 08-03-2007, 09:49 PM
kprice1658 is on a distinguished road
Whats the best way to get these grooves..
New to Rhino - about 1 week and trying to absorb everything. I have alot of this style of 3ds to do for molds - and they all have some type of surface design on them - not sure if you'd call it engraving or not.
You can see from the pics - I can't figure out how to get the rings, ribs, grooves - to my surface. These need to be milled out - so must be part of the mold.
It seems it should be simple - I'm sure I just don't know all the features / tools of Rhino. (I even made a bunch of ellipses - like donuts => array - looked stupid!)
Appreciate any guidance....
thanks,
Kevin
ID:	41690   Click image for larger version
ID:	41691   Click image for larger version
Old 08-03-2007, 11:11 PM
turmite is on a distinguished road
Well Kevin the first shot looks like a boat tail bullet but the other two seems to be lures? How close am I?
What type of groove is it you are needing. A spiral around the part. Is the groove to be in the part or in the mold?
If you have a sample 3dm file you can zip and attach it would certainly help.
Mike
edit: ok I see the grooves in the two sample part photos.
No greater love can a man have than this, that he give his life for a friend.
Old 08-03-2007, 11:40 PM
Mike,
The 1st shot - is what I was starting with to get the basic shape of the worm bait. Its not really a spiral - because each groove is like a ring around the shape that connects - not just spiraling around the length. Does that make sense?
Old 08-03-2007, 11:48 PM
Kevin are you talking about worms with the bands around them? If so, I can hellp you pretty quick with that. Grooves running lengthwise or radially around the worm can be done quite easily too, but will require me a little more time.
Mike
Old 08-03-2007, 11:54 PM
Yes - the bands that run around the worm.
The frog has a different pattern about it - but I figured the worm would be easier for me learn with for my first project.
Kevin
Old 08-04-2007, 12:04 AM
Kevin pm me your email address and I will whip one out.
Mike
Old 08-04-2007, 12:12 PM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Talking
turmite did you get it? I was wondering what approach you had taken?
I made some arcs, joined them, and then bent the top then revolved rail...
Hey check out my website...www.cravenoriginal.com
Thanks Marc
Old 08-04-2007, 12:15 PM
pointcloud's Avatar
Prototyper
Talking
Hey on the frog... Don't draw the lines in just make the toolpath do that work for you?? Better yet do that for the worm too? It would be easierererereer.....
It looks like an angle on a paralell finish path with to much step...
Thanks Marc
Old 08-04-2007, 05:54 PM
So you think I can do the bands - designs on the body's of these baits by using the CAM software and the tool paths? I haven't even looked at CAM software - other than some demos. My machine comes with SheetCam or I can get aupgrade to Sprutcam. I thought about getting RhinoCam to keep everything easier. Any recommendations on which one to start with?
Kevin
Old 08-04-2007, 08:04 PM
pointcloud's Avatar
Prototyper
I have rhinocam.. btu if your just goin to make a few lure mold, it might not be justified... But I use it a lot and would not trade it for anything...
You need to understand toolpaths.... well if you don't understand.. you will need to... A 1/2" ballmill like a pencil. drawing lines on paper.. left to right advancing from the bottom to the top in incriments of .375 will cause a ridge and the reason is the ball shape combined with the advance of more than the radius..
I have sheetcam too. I have not ever tried to make a path like that.. I use it for plasma tool paths...
look around the forums for simulator screen shots... You'll see the stripes...
Look at this video I found it gor you.. See the lines that run the same direction as the tool is going? thats is, and if you use a ball shape you'll get the result you are looing for.. But you can program it in rhincam for sure..
http://www.youtube.com/watch?v=9EueG...elated&search=
Thanks Marc
  #11   Ban this user!
Old 08-04-2007, 08:32 PM
Hey Kevin,
Yep I got it and have been busy today installing a new dishwasher so you know which person I'm trying to make happy!
I been gone the rest of the day and will back in a couple hrs. I will send it to you then, but it does look like you are making progress. I used revolve to get what I have but it only has a single band. I see you are wanting much more detail.
I'll go back and redux the model!
Mike
  #12   Ban this user!
Old 08-04-2007, 10:34 PM
Pointcloud - I think I understand what you're saying with the toolpath layout to get what I need. Once I get my machine up, I can do some testing.
Turmite - no problem - sounds like you've got you're priority's right!
Guys - I'll be gone out of town 'til Thursday - so no hurry with your help. I'll touch base when I get back. My machine will be arriving Friday - so I'll be busy getting it setup and tested out.
You guys are great for helping - hope I can return the favor some day..
Kevin
[IMG] code is Off
Grooves MCX jorgehrr Mastercam 2 04-18-2007 03:58 PM
Question about cutting grooves in aluminum flycast General Metalwork Discussion 8 09-19-2006 11:17 AM
How do you cut wide grooves with a small bit? randyf1965 DIY-CNC Router Table Machines 0 04-26-2006 08:09 PM
Machining grooves itsme General Metalwork Discussion 8 10-03-2005 01:07 PM
I'm looking at getting CADCAM but am unsure if its possible to make grooves like..... Darc General CAM Discussion 1 11-12-2004 10:28 AM
