Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 07-29-2007, 09:04 PM
daisydog is on a distinguished road
rhino to madcam
I am trying to create an nc program in macdam using a wireframe drawing imported into rhino 3d v4, but madcam will only read surface or solids.
How can a wireframe drawing be converted to suface?
Thanks Joe
Old 07-31-2007, 01:15 PM
pointcloud's Avatar
Prototyper
pointcloud is on a distinguished road
Thumbs up
Type into rhino _MeshPolyline then select the set of CLOSED lines.. If there not closed it will not work... If they are all closed then it may be a mess.. If it is a Mess Type Explode (select the part) into the rhino and then "JOIN" the lines back so you may get the surface right...
Or Mesh menu > From Closed Polylines> prompted to select
JOIN will put togather lines and surfaces that touch.. Control+j is the same...
You should have no trouble getting a toolpath, but in the event you do you can convert the mesh... Although if it is a big part then the mesh is small in operating size...
Lastly, After the mesh is on the surface hit the F10 to see all the points that make the surface, from here you can munipulate endlessly....
Good luckkkkkkk
Marc
Name:	from closed polyline.jpg‎
Hey check out my website...www.cravenoriginal.com
Thanks Marc
[IMG] code is Off
madCAM 4 for Rhino 4.0 Shipping Robert Schutz Product Announcements & Manufacturer News 0 03-07-2007 03:49 PM
Rhino + MadCAM Bill.T Rhino 3D 0 10-27-2006 12:12 PM
Rhino+Madcam > Mastercam? robinsoncr Rhino 3D 16 08-03-2006 07:52 PM
madCAM, a 3D CAM plug-in for Rhino 3.0 JOM Product Announcements & Manufacturer News 0 02-13-2006 03:36 AM
