| Rhino 3D Discuss Rhino 3D software here. |
| HERE IS A THOUGHT - GIVE IT A TRY::: Set units to the right spec - inches, ft, mm etc (PROPERTIES etc -- thats the icon 3 or 4 over from left on the first icon bar..) Then: 1 Select (the active) viewport (The one you will import to...) 2. Select Dimension (Linear) from top toolbar - draw a dimension that is close to you want in the direction you are concerned... 3. From (Main/TOP) toolbar--Pull down Scale - pick 2D - work the size 4. Size 'til you get it right? I've worked some that are 10,000x off (mind you these were *.dxf files, using this way - sorry its crude, but I'm self taught - I think it should work for dwg too -- I'd think.) Just a thought - give it a try Hope that helps! Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| There are several things that may be going on here. A) ACAD file formats (dxf, dwg) don't contain real specific units info the way an IGES or STEP will. So, in many cases, the file will take on the units of the importing program at the time of the import. B) If the drawing is in paper space in ACAD, it may cause problems. The import may take on the scale of the paperspace detail, for example. The best procedure is as follows: 1) Open Rhino. 2) Set the units to whatever the units of the imported file were drawn in. For this, you obviously need to know what they are. Usually this means you need something with dimensions like a paper print, verbal instructions from the sender, etc... If you open the file once and it is dimensioned, you might be able to figure it out for yourself. 3) If you have layouts in your file (Rhino 4 only, the equivalent of paperspace), make sure they are not active (set the normal Top viewport to be active, i.e. "model space"). If you don't have layouts in your file, you don't need to worry about this. 4) Use Import to import the file, not Open. Check to see if the dimensions are correct. 5) If it's still wrong, you can always try scaling the entire file using a known dimension as a guide. If you still are having problems, post the file to be imported here, on the Rhino newsgroup, or if confidential, mail it to tech@mcneel.com or upload it via their website. --ch |
| Importing .dfx files and working with wizards | Revtech | Mach Software (ArtSoft software) | 4 | 08-09-2006 08:55 PM |
| About Importing Files | Gorillakilla | Mach Software (ArtSoft software) | 7 | 04-11-2006 04:37 PM |
| Importing files to turbocnc | mikburts | TurboCNC | 2 | 07-17-2005 06:35 PM |
| importing 3d iges files | jallen | BobCad-Cam | 0 | 07-07-2005 08:35 AM |
| importing files to machine | fastolds | GibbsCAM | 2 | 06-23-2005 07:48 AM |
