I programmed an alias. When I type "A S" and right click, it inverts the selection and hides everything else. Useful when working with many parts/pieces.
I thought i'd just share my customised keys because they have made my life so much simpler![]()
for F1
"disableosnap toggle" which means i can turn snap on or off at a click.
for F2
"delete"
for F3
"0" which i use often to automatically input to the exact center of everything. Useful when mirroring etc.
all this means is my left hand has to move rarely far at all![]()
I use this to zoom extents...
Hey check out my website...www.cravenoriginal.com
Thanks Marc
The "ALT" key will also toggle Disable/Enable Osnaps whiile held down...for F1
There's a mirror axes toolbar here:for F3
http://en.wiki.mcneel.com/default.as...olbarPage.html
For lots of other info about customizing your Rhino work environment, see:
http://en.wiki.mcneel.com/default.as...riptsPage.html
--ch
Ta. BUt what i like about my configuration is that my left hand can span the shift, escape and f1 2 and 3 and doesnt need to move much at all.
having delete on f2 is great because i do a lot of "try and see" designs.
And yes I've got a lot of the tool bars customized to suit my needs too. Done during those "working but not really working" times![]()
