OK. I have done several of the Rhino Tutorials and I am trying to figure out the best way to model the top half of a body, minus the arms. A sculpture of sorts that I wish to build.
Should I start like I did with the duck and manipulate control points? Should I sketch two views by hand and then try to loft? Should I try some rail outlines and some revolves? I am not great at Rhino, but I can make my way around a 4 view and follow directions....
Also, if you are making say horns, would you suggest making the curves and then rail revolving. Because, correct me if I am wrong, once you extrude a shape, you can't turn on the control points and deform the ends or bend them, can you?
LinkBack URL
About LinkBacks
