Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 06-27-2006, 08:18 AM
robinsoncr is on a distinguished road
Eliminating Pockets
Hi Everyone,
I'm trying to get this guitar body ready for the cnc. I think it would be much better to eliminate the pockets for the pickups, neck socket and hardware holes. That way, I could machine the surface of the body as a whole, then use pocketing tools to machine out the cavities and drill routines to bore the hardware holes.
Question is: Now that I have created these pockets, how do I put a surface back over them? I would like to leave the bottom of the pockets there. I would then have a reference to do the pocketing routine. I have tried researching the manual to no avail. I also tried deleting the poly-surfaces of the pockets and then trying the rebuild command but it didn't work.
Any help would be greatly appreciated.
Thanks,
Chris R.
Old 06-27-2006, 08:38 AM
RandMan is on a distinguished road
On most of them you can do an untrim command and select the edge of the hole. Since a NURB surface is a big square when you untrim it, it removes the trim information which makes the hole.
On the neck pocket: Duplicate the edges (dupedge) draw a line to connect the front and then do a edgesurf or whatever to create a cover surface. This approach won't build a duplicate but it should be close enough to keep your bit from falling in the hole.
Nice work. I generally keep a copy of a surface like a top for machining and then make the pretty one with the cavities.
Old 06-27-2006, 09:36 AM
Randman, thanks for the tips! I'll give'em a try.
Chris
Old 06-27-2006, 10:48 AM
JOM JOM is offline
JOM is on a distinguished road
Chris,
It is also possible to use Patch.
1) Use Solid Tools-Extract surface and extract the top surface.
2) Use Curve from Object-Duplicate border and duplicate the borders of the trimmed top surface.
3) Use Surface-Patch and create patch surfaces from the borders of the pockets.
I also did create some sample toolpaths in madCAM on your model. I am not sure if this is the way you would like to have it but I hope it will give you some help.
Joakim
Old 06-27-2006, 11:21 AM
Joakim, that is exactly what I wanted to do! And that's exactly how I wanted to machine the part. Thank you very much! I'll let you know how it works on the cnc.
Thanks,
Chris R
[IMG] code is Off
