Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 06-15-2006, 11:55 AM
robinsoncr is on a distinguished road
A little help from the Pros
Ok, I'm working on this guitar. I'm trying to figure out how to blend the surfaces from the guitar neck to the headstock. I'm also trying to blend the surfaces at the heel, where the neck transitions to the body.
I'm not sure which command I should use. Any help would be greatly appreciated!
Thanks,
Chris R.
Old 06-15-2006, 12:58 PM
dcd121 is on a distinguished road
surface from 2,3,4 corner points or surface from edge curves might work.
[IMG] code is Off
