Results 1 to 4 of 4
Thread: Delete Duplicates command
    Feb 2005
    Sweden
    Hi all cadwizards
    Under the 'Edit tools' there should be a command for deleting duplicates, however I cant seem to find it.
    http://www.rhino3d.com/features.htm
    Sometimes you get duplicates that you just cant see and it would be great to remove them automatically instead of now -clicking on every little line just to see if there is one line or if there is one or more duplicates!
    Any help will be appreciated
    MD
    Moderator
    Apr 2003
    Hi MD,
    There is not a "Delete Duplicates" command that I know of. However, it is easily accomplished by using the SelDup (Select Duplicates) command, then just deleting the selection. If you want, you can string together the commands in a button, or alias:
    ! _SelDup _Delete
    Keep in mind that SelDup selects exact duplicates. If you have 2 lines on top of each other, but they were created in different directions, they are not really exact, so they will not be selected. If you want to delete similar objects as opposed to exact duplicates, there is a plug-in that can do this. If you are interested, I will do some digging and find a link for you.
    Dan
    Feb 2005
    Sweden
    Hi Dan
    Thank's a million for the info about the seldup command.
    If you could find that link for the plug-in it would be really nice to try it out.
    I cant thank you enough Dan!
    Cheers MD
    Moderator
    Apr 2003
    http://www.rhinoman.com/plugins.html
    Take a look at the "SuperSelect" plug-in.
    Dan
