Results 1 to 3 of 3
Thread: How to quantise a curve into steps?
    Apr 2012
    uk
    I'd like to mill a cone shape out of multiple layers of MDF stuck together. However, I do not want the milling machine to taper the edges. All I want is for the machine to cut a series of circles that I can stack on top of each other.
    How do I convert a solid cone in Rhino3D into a series of disks?
    If the height of the cone is 30cm and I'm using sheets of MDF that are 2cm thick, I'd like Rhino3D to be able to convert my smooth cone into the 15 disks so that I can feed those dimensions to the milling machine.
    Feb 2010
    us
    the_ether-
    I think this is what you are asking. In Rhino if you have the cone defined as a surface go to the > [curve] dropdown menu and then click on the >[curve from objects] menu at the bottom and the select> [contour]. This will slice any geometry at whatever interval you set in the command line. I then defined a surface and used the project command to push the curve profiles to [0] Zaxis and shuffled out. You can then just profile the curves at this point in MDF. see photo example attached.
    hope this helps,
    -flux
    Attached Thumbnails Attached Thumbnails How to quantise a curve into steps?-cone.jpg
    Apr 2012
    uk
    Quote Originally Posted by flux_001 View Post
    the_ether-
    -flux
    Thank you Flux. That was very helpful.
  1. Need Help!- Smooth curve
    By Rocketeer_88 in forum UG NX
    Last Post: 08-08-2011, 01:09 AM
  2. S-N curve
    By aaron_js in forum Mechanical Calculations/Engineering Design
    Last Post: 08-05-2011, 12:12 AM
  3. MC learning curve?
    By Ted Filley in forum Mastercam
    Last Post: 03-09-2011, 08:42 AM
  4. Newbie- Creating a Curve
    By n1bpd in forum G-Code Programing
    Last Post: 04-10-2009, 01:59 AM
  5. Full Steps -vs- Micro Steps
    By DJB282000 in forum General Electronics Discussion
    Last Post: 12-29-2005, 12:25 AM
