Results 1 to 3 of 3
Thread: user input
    Apr 2004
    GA/USA
    user input
    I am considering purchase of a 3D modeling program to develop a parts blow-up for a product user manual. Several years ago I spent a few hours with Rhino and liked it. So here are a few questions.
    1. Will Rhino do exploded and cut-away views?
    2. Do I need to purchase some separate rendering package to view/print my models (I'm still confused about this)?
    3. Do I get a reusable license key or must I acquire a new activation key each time I put it on a new computer?
    4. Will Rhino run on XPSP2?
    Doug
    Sep 2004
    Switzerland
    Not automatically. There are lots of tools in Rhino to help you do this more or less manually, but no one-button solutions. Note that although Rhino does handle solid volumes, it does not require them to stay solid, so if you start trimming parts, you will open them up unless you use the specific solid editing commands.
    Rhino has a built-in renderer for basic stuff, but it is not really photo realistic. If you need photo realism or advanced rendering options, you will need a 3rd party render plug-in like Brazil, Maxwell or V-Ray. Rhino 5's native renderer is quite a bit better than V4. Rhino 5's superb new advanced display modes may allow you to go with simple screenshots and forgo a rendering entirely.
    You get a reusable license key and it is allowed to install Rhino on as many of your own computers as you want, as long as you are the only user.
    Rhino 4 will be no problem. Rhino 5 should run on XP as well, but I don't know how much longer that OS will be supported.
    --ch
    Apr 2004
    GA/USA
    Thanks ch;
    The assembly is simple enough that manually exploding it shouldn't be too painful. Simple rendering will suit my needs.
    Doug
  1. Need Help!- VCarve Pro user needs Aspire user help
    By ntww in forum Vectric
    Last Post: 10-07-2009, 10:08 PM
  2. User input variable - best way?
    By markkirby in forum G-Code Programing
    Last Post: 06-01-2008, 10:02 PM
  3. Geckodrive user input requested
    By Mariss Freimanis in forum Gecko Drives
    Last Post: 10-15-2006, 11:26 AM
  4. M109 Interactive User Input
    By axis overtravel in forum Haas Mills
    Last Post: 07-31-2006, 04:55 PM
