Results 1 to 3 of 3
Thread: trimming and Joining curvs
    May 2007
    I have been using Rhino for awhile now
    seems like I can join objects in Rhino ..
    but when I import them into CAM software they are separte
    and turning CP on and redrawing and Arc seems time consuming if you have
    many curvs ... any input would be helpful
    Thnks
    Registered BurrMan's Avatar
    Dec 2008
    Hi Kojak,
    Look at the "rebuild" command.. Joining still keeps the segments and can be seperated (or as in your CAm software, still seperated... Rebuild will make one contiguous curve.. Look for the tolerance option for rebuild.. .
    May 2007
    Quote Originally Posted by BurrMan View Post
    Hi Kojak,
    I use rebuild all the time
    most of the curvs are lofted so I rebuild with minmal UV lines
    I guess this time I was in a hurry
    and just trimed and joined the 2 ...
    I will try it out
  1. Trimming in an assembly
    By Farmers Machine in forum Alibre Design
    Last Post: 03-21-2011, 12:10 PM
  2. Trimming Circles and Lines
    By jcnewbie in forum Mastercam
    Last Post: 01-06-2010, 09:18 PM
  3. Need Help!- Trimming surfaces
    By dpark1 in forum Mastercam
    Last Post: 07-27-2009, 12:54 PM
  4. Need A Quote- router trimming
    By snocutt in forum Employment Opportunity
    Last Post: 08-21-2008, 01:46 PM
  5. Trimming in bobcad
    By Parameter in forum BobCad-Cam
    Last Post: 12-30-2005, 04:07 PM
