Results 1 to 5 of 5
Thread: threads on baseball
    Apr 2005
    us
    Cool threads on baseball
    could someone explain how to put the threads on a ball ... how to make them flow. Thanks Brady
    Registered BurrMan's Avatar
    Dec 2008
    I think you want to look at this command:
    ArrayCrvOnSrf
    Here is a link to a 3dm file I setup to do it.. (I didnt look at a baseball, so this is just the idea.. You should be able to make it look how you want.)
    Rhino Baseball file
    I projected a curve onto a sphere to use as the path. I created a single "Thread" off to the side to use the array command on. I also swept some profiles along that path for the center part. Then I booleaned them all together.. Everything has a layer and a name.
    Apr 2005
    us
    HOW DO YOU PUT A LINE ON A SPHERE SURFACE
    i WOULD LIKE TO KNOW THE STEPS IN ORDER ON HOW TO DRAW A LINE AND APPLY IT TO THE SURFACE OF A SPHERE. THANK YOU, BRADY
    Sep 2003
    Brady, Here is a tutorial that I made up a while back. It should answer your questions.
    [URL="http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3857091&ebot_calc_page#message_3857091"]
    Sep 2003
    Hi, Yes, that is what you'll see when go to active threads area. But, once you are logged in to the forum you can access that URL that I posted here at CNCzone.com.
    1. New info on cnc wood copy lathes for baseball bats
      By copylathe in forum Wood Lathes / Mills
      Last Post: 06-01-2009, 07:55 PM
    2. What Programs would you Advise to get for designing Wood Baseball Bats
      By Minna in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 03-11-2008, 09:39 PM
    3. Need Help!- Help Wanted G-codes for Wood Baseball bats.
      By Minna in forum G-Code Programing
      Last Post: 03-10-2008, 11:15 PM
    4. Why do they play the organ in baseball?
      By ynneb in forum CNCzone Club House
      Last Post: 08-24-2004, 07:27 AM
    5. Saving threads or parts of threads???
      By flybynight in forum Forum Questions or Problems
      Last Post: 02-22-2004, 01:19 AM
