I am working to convert an AutoCad file I was given to 3D. The problem I am running into is when I go to join the lines I am having problems getting them to join.
Even after I get them to join when I go to extrude the joined line I run into problem were the extruded edge is jagged and has gaps in it. Making it impossibel to cap and make a solid.
I have run over the line I am extruding from and see no gaps or voids and it shows up as a solid line....Is their an easy fix or command I can run?
LinkBack URL
About LinkBacks
