I have a new copy of Rhino3d. Using Windows 7 64 bit. The program installed and works properly, but every time I close the program, it generates a .dmp file thinking that it had crashed. I bring up the saved work and it goes fine. Should I be concerned?
Yes, you should be concerned, as this is not normal behavior. It may be a problem with your installation. Do you have the latest service pack installed (SR8)? Do you have UAC on? Are you administrator of the computer? Did you install the program as administrator? I would also contact either your reseller or the McNeel home office responsible for your area directly and have them help you. --ch
