Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Rhino 3D
Rhino 3D Discuss Rhino 3D software here.
Old 05-12-2005, 12:16 PM
ddgman2001 is on a distinguished road
Capping problems with extruded curve
I'm trying to draw up a guitar body. Starting with the profile curve, I can extrude the curve to the thickness I want, but Rhino is unable to cap the top and back.
Any suggestions?
Old 05-12-2005, 12:59 PM
DAB_Design is on a distinguished road
the curve probably isn't 'flat'. select it and use 'projecttocplane' in the top view. Then move it back to the height necessary (it will move it to Z zero). Then extrude and cap.
Dustin B.
I hear and I forget.
I see and I remember.
I do and I understand.
Old 05-12-2005, 02:01 PM
Thanks for that. After projecting to cplane, it still extrudes fine, but refuses to cap. I tried converting the curve to a polyline. No luck.
The curve is made up of a spline joined to two nurbs elements which appears to be the problem. I replaced the nurbs elements with a line and a curve and now it's working.
Old 05-12-2005, 02:05 PM
More than likely then, the curve probably is not closed. You'll need to find where the gap is, and fix (close) it. Then extrude - cap.
Dustin B.
[IMG] code is Off
Accuracy problems i228208 General CAM Discussion 26 05-30-2004 01:31 PM
Project a curve keithorr OneCNC 1 04-02-2003 10:36 PM
