Results 1 to 4 of 4
Thread: Extrude a cut?
    Jun 2007
    Extrude a cut?
    Just learning Rhino, I'm coming from a background of Inventor 3D. I'm looking for a function like "extrude a cut" from Inventor, is there such a function on Rhino?
    i.e. you draw a sketch on a solid and extrude it out (cut it out) instead of extruding a solid in like what normal extrude does
    Mar 2003
    Shelby Twp, MI....USA
    Try extruding a solid and then boolean subtract it. Same thing, but an extra step. I believe that only parametric modelers have the "extrude cut".
    Sep 2004
    Switzerland
    You can also have a go wth the function Wirecut. It acts a lot like Extrude Cut and more... You can also use it to section solid volumes etc... --ch
    Jun 2007
    Cool thanks guys!
    I was able to cut through the material with both boolean difference and wirecut. This software definitely needs some "getting used to"
  1. Extrude hone Media
    By bl409 in forum Mass finishing equipment/media/stratigies
    Last Post: 11-02-2011, 04:03 PM
  2. Unigraphics Extrude / sketcher
    By greenchair in forum General CAD Discussion
    Last Post: 01-05-2009, 10:10 AM
  3. Need Help!- Unable to extrude along path
    By PeteGallo in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 03-15-2008, 03:16 PM
  4. SW 2007 Extrude and chafer?
    By john_t_h in forum Solidworks
    Last Post: 03-11-2008, 07:20 AM
  5. extrude slot at angle
    By PETE1968 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 04-10-2006, 09:01 PM
