Need Help! Pasting into command line works with single line pastes, but not multiple
Results 1 to 3 of 3
Thread: Pasting into command line works with single line pastes, but not multiple
    Dec 2017
    Default Pasting into command line works with single line pastes, but not multiple
    I am having trouble executing while pasting into the command line.
    When i paste these commands ( attachment: create box.txt ) into rhino it does not work as i expect.
    Desired: If i run commands from file or copy/paste the whole contents: only one box is created (attachment: only one.jpg)
    What i get: If i copy / paste lines one-by-one:the complete model (complete box.jpg)
    This was working before to create whole model with one paste, and i don't know what changed.
    Rhino 3D:Version 5 SR14 64-bit(5.14.522.8390, 2017-05-22)
    Win10 pro - 64 bit, fall creators update.
    Thanks for the help.
    Attached Thumbnails Attached Thumbnails Pasting into command line works with single line pastes, but not multiple-complete-box-jpg   Pasting into command line works with single line pastes, but not multiple-onlyone-jpg
    Attached Files Attached Files
    Dec 2017
    Default Re: Pasting into command line works with single line pastes, but not multiple
    anyone have any clues as to what could be going wrong? I changed line endings but there was no change.
    Dec 2017
    The problem has to do with material references. Specifically that the rhino materials were not embedded into the file. No script command is available to embed them.
