Problem
Results 1 to 5 of 5
Thread: Problem
    Jan 2008
    Default Re: Problem
    Hi Masoudex,
    I would make this using a sweep 2 rails command.
    Make open vectors to follow the curvature in the Y axis (according to the photo positioning), then make a few profiles in the X axis. Run those as a two rail sweep,
    More views of the leg would be better, isometric preferred. You probably need to make this in a few parts then surface blend them together and join.
    Let me know if you need more assistance on this. If you do, I'll need to see an isometric drawing so that we get all views related to this shape.
    Cheers,
    Bruce
    Sep 2017
    Iran, Islamic Republic Of
    Default Re: Problem
    Quote Originally Posted by asbestosfriend View Post
    Hi Masoudex,
    Cheers,
    Bruce
    Thanks Bruce. I will do what you said and tell the result.
    Mar 2010
    Russia
    Default Re: Problem
    I made similar looking legs.
    Problem-noga-260v1-9-jpg
    Problem-noga-260v1-10-jpg
    This one was created by 2rail sweep, then surfaces was joined.
    3 rails, about 6 profiles.
    But yours a bit complex. I never made forms like this, but this one uses same algorythm:
    Problem-carga5-jpg
    Lower front part of this leg was made by curve network, all other with 2rail sweep.
    It's simple.
    Sep 2017
    Default Re: Problem
    Quote Originally Posted by Melkiades View Post
    http://www.cnczone.com/forums/attach...d=374648&stc=1
    http://www.cnczone.com/forums/attach...d=374650&stc=1
    http://www.cnczone.com/forums/attach...d=374652&stc=1
    It's simple.
    Thanks dear @melkiades.
Problem
Problem
