can't import/open .pdf file
Results 1 to 5 of 5
Thread: can't import/open .pdf file
    Sep 2014
    Default can't import/open .pdf file
    Hi.
    I get the attached message when I try to open a pdf file. Others open OK but every now & then I run into this problem.
    Why dies this happen, and how do I correct or work around it?
    Thanks,
    Rob.
    Attached Thumbnails Attached Thumbnails can't import/open .pdf file-pdf_fail-pdf
    Gold Member
    Apr 2004
    Oakland CA USA
    Default Re: can't import/open .pdf file
    What were you expecting to do with the PDF file in Rhino? Rhino is a 3D program; PDF is a 2D format. At best, you could bring it in as a background bitmap and trace over it. If Rhino won't accept it as a bitmap, convert it into JPG or BMP format and try again.
    Andrew Werby
    Website
    May 2006
    There are "pdf to dxf converters" online.
    Search the phrase
    Sep 2014
    Well...I was planning to model something loosely based on a plan...
    Thanks for the tip re the converter!!
    Rob.
    Jan 2016
    A pdf can contain both vector and raster formats. Most likely the pdf you are trying to import is a raster format (pixel image). Rhino is looking for vector that it can use. Your only option would be to use it as a background and trace it in Rhino. By the way Rhino is not just a "3d program" it is very good at 2d.
