Give angle of exit or demoulding
Results 1 to 2 of 2
Thread: Give angle of exit or demoulding
    Feb 2012
    Peru
    Default Give angle of exit or demoulding
    Hello all, I want to give angle of departure of 14 degrees to the letters, I want to know how you can do? thanks you
    Member routalot's Avatar
    Dec 2003
    Default Re: Give angle of exit or demoulding
    Are you intending to produce individual letters or cut letters into an object?The process is fairly similar in that you select the outline of the letters and use the extrude curve-draft feature to create the surfaces or solids you require and you will be prompted for the draft angle,which in your case will be 14 degrees.The depth will be positive or negative according to your needs as mentioned earlier.
