Boolean operation on STL files
Results 1 to 2 of 2
Thread: Boolean operation on STL files
    Feb 2007
    UK
    Default Boolean operation on STL files
    Hello,
    Can you tell me if this is possible please.
    I have a STL file of a part that I need to make a mould from.
    I imported the STL file and then created a cube that is big enough to cover half the model.
    When I try to do a Boolean operation, it won't select the STL object.
    Any help appreciated.
    Thank you.
    Mar 2006
    Default Re: Boolean operation on STL files
    In order to do boolean operations on STL files, you have to convert your other object into a Mesh, as STL files are imported as meshes, not as NURBS surfaces/solids.
    So, in order to do this, take your created cube, go to the upper menu and go to the MESH tab, and choose MESH->From NURBS object. then select your box/cube.
    Now you have a cube mesh.
    Now you can do Mesh Boolean Operations such as Union/Intersection/Difference, by going to the MESH tab and selecting MESH Boolean.
    That should take care of it.
