Need Help! How could I model this?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: How could I model this?
    Mar 2016
    United Kingdom
    Question How could I model this?
    I've been scratching my head confused as to how I'd go about creating this effect on a sphere for one of my projects. Has anyone got any ideas as to how I could go about this?
    Attached Thumbnails Attached Thumbnails How could I model this?-7809-10a-jpg
    Mar 2010
    Default Re: How could I model this?
    Project curves command?
    Mar 2016
    United Kingdom
    But then once i project curves how do i get that layered effect?
    Jun 2014
    Is that a machined effect? Just looks like the woods grain to me
    Mar 2016
    United Kingdom
    @ Jon.N.CNC It might be the wood grain effect. But I think I could still recreate something similar on rhino?
    Mar 2016
    United Kingdom
    Maybe that isn't the best image but what i'm after is something like thisHow could I model this?-wave_2-jpg
  7. #7
    Jun 2014
    Quote Originally Posted by enesoz View Post
    I see, that would have likely been done with software like artcam or aspire, both have z level layering adjustment.
  8. #8
    Mar 2016
    United Kingdom
    can i do that on aspire with a sphere not a flat surface?
  9. #9
    Member Dan B's Avatar
    Apr 2003
    Ontario
    Is this for a rendering, or do you want those markings to be part of the model? If you just plan to create an image as opposed to manufacturing the object, (though additive or subtractive means) then it's pretty simple to add a material to the object.
    Dan
  10. #10
    Jun 2014
    ahh no sorry don't think it does.
    Modelling it as a revolve would give you 360 degree even layers. You could model a few of these with layers in different places, cut and splice together and use fillets to smooth the joins.
  11. #11
    Jun 2014
    Quote Originally Posted by Jon.N.CNC View Post
    I'm not sure in rhino but in inventor/360 you can create a 3D sketch and create splines around the sphere for the extruded 3D extruded sketch to follow.
  12. #12
    Mar 2016
    United Kingdom
    I need the markings to be part of the model, its going to be manufactured so the relief waves need to be physically in the model
  13. #13
    Jan 2007
    then just use a program like blender, or mudbox....
    or you can use 3dcoat...
    the hobby version I think 100..
    possible maya also can do it..
    meshmixer also capable to lay on surfaces this woodgrain..
    from technical view, you need groves actually
    that's why z brush, or 3d coat can make it effectively.. you define a kind of ""brush"" and draw on the sphere..
    btw, what is your plan to machining it? and of what? steel? aluminum, or plastic?
  14. #14
    Mar 2016
    United Kingdom
    I like the look of meshmixer, it seems like its got a mild learning curve. Would you be able to guide me to a tutorial or the specific tools and a little method I could use to do it on meshmixer
  15. #15
    Jan 2007
    heres some tutorial
    first create a ball, and ""bent surfaces""
    these surfaces representing the wood grain
    import as obj format in meshmixer
    in meshmixer they are separated objects..
    set sculpting tool to ""PINCH"" and start to draw a line along the intersection of the auxillary surfaces and the sphere..
    after the first line, turn off the plane visibility so you can go to next
    when you model the planes imagine the rings as closer to the tree core, they are smaller radiuses..
    make little odd them, not exactly radius.. if you know I mean..
    Attached Thumbnails Attached Thumbnails How could I model this?-basic_shapes-jpg   How could I model this?-modeling-jpg
  16. #16
    Mar 2016
    United Kingdom
    thanks a lot i'll give this a go!
  17. #17
    Member TedKyte's Avatar
    Feb 2007
    Here is a modeled version using "Project" and another using a wood grain texture.
    How could I model this?-project-jpg
    How could I model this?-wood-texture-jpg
    Ted
    http://www.RhinoCanada.com or http://www.ted-kyte.com
  18. #18
    Feb 2007
    The combine the "Project" with "Offset Surface and "Loft the edges. Here is a quick example.
    How could I model this?-formodeling-jpg
    Ted
  19. #19
    Mar 2016
    United Kingdom
    Thats great TedKyte really helpful, if I was to do the opposite and instead of the waves going in, have them as a relief, what command would I use for the last step?
  20. #20
    Feb 2007
    Here is a better way, use 2 spheres, create your wave shapes and extrude them through both spheres.
    Split both the spheres with the surfaces, then split the surfaces with the sphere pieces, then delete the unwanted inside sphere surfaces and the unwanted outside sphere surfaces and it will join up as a closed poly surface that is machinable.
    How could I model this?-2sphere-jpg
    That makes the relief pieces horizontal. If you want them normal to the original surface then use the first method with "Offset Surface" and make the direction outward instead of inward.
    Ted
